How to clean foggy lens on '97 SC300?
The passenger side headlight lens is very foggy. Is there a way to take it out to clean or better, clean it without having to remove it first?
"Foggy" sounds like you have condensation inside your headlight assembly. Search in the forum for a fix. I had to drill some holes in the bottom of my assembly even after taking it apart and resealing it. No more condensation ...
follow both links below, and your lights will look brand new
https://www.clublexus.com/forums/sc-...finishing.html
https://www.clublexus.com/forums/sc-...headlight.html
Apply some polish and just buff it out. It should clean the lens pretty well. Afterwards if it's still slightly yellowish, you will need to remove the the lens and polish the inside as well. I used the oven trick to do mine.
We took the headlight apart afterwards, he was bored and threw some clear film on it to prevent it from oxidizing again. Till this day the headlights still look clear and bright..
Stemmer
RX - 1st Gen (1999-2003)
10-08-12 05:26 PM
