Change Water Pump on SC 400 without messing with the timing belt
Old 01-07-10, 12:49 PM
kminev
kminev's Avatar
Default Change Water Pump on SC 400 without messing with the timing belt
Is it possible to change my water pump without touching the timing belt?
I looked at the forum and found very useful article, but nowhere specifies my question.
Thank you.
Old 01-07-10, 12:54 PM
97-SC300
97-SC300's Avatar
you have to remove the timing belt to get to the water pump. so you might aswell replace it. or reuse it if its in good condition or just replaced resently.
Old 01-07-10, 06:30 PM
xknowonex
xknowonex's Avatar
Timing belt is 30 bucks man. Don't be cheap, replace it along with other seals. It will save you the headache down the road
Old 01-08-10, 12:54 AM
prolifik22
prolifik22's Avatar
what other seals are there?.sry for a thread jack but yea the belt is cheep juz get a new one...also i heard u need a specific tool to take the crank pully off??
Old 01-08-10, 01:45 AM
xknowonex
xknowonex's Avatar
Well in the front of the engine, you have the crank seals and cam seals. People should replace those during the 90k service (timing belt water pump etc). That is how it is for our SC300s so I assume the same parts are accessible during the timing belt replacement on the SC400s as well. I might be wrong.
A lot of times people replace the belt and don't replace the water only to get screwed over when they have a messed up water pump or a leaking cam seal at, say, 130k miles. Do it at once and save the headache. Cardinal Rule: Maintenance over Mods
Old 01-08-10, 05:26 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I have replaced mine on my 400 once and its alot of time and patience. You will be glad you did it while you are in there. I would also flush the coolant, change plugs, wires, and and three of the seals while you're there. Heres a perfect link for the 400.. Let us know how it goes. Its for the LS400 but same principle. Good Luck... To get the crank pulley off, I would slide a 22mm socket with the longest ratchet I could find, then slide a very long piece of pipe over the ratchet, and wedge it under the drivers side frame of the car, then BUMP the starter, DO NOT crank it... Then will loosen the crank pulley like butter!
http://www.lexls.com/tutorials/engine/timingbelt.html
Old 01-08-10, 05:54 PM
SHOLEXMAN
SHOLEXMAN's Avatar
LOL this thread nothing else....
Old 01-09-10, 07:31 AM
TheRonTom3
TheRonTom3's Avatar
Hmmm and i thought there was nothing harder than installing a starter on the Sc400. lol
Still for some reason it doesnt look that bad to me. Just super time consuming
Old 01-13-10, 12:19 PM
kminev
kminev's Avatar
Thank for everyone input. I was wondering if the water pump was only serpentine belt driven therefore replace for an hour or so, but I guess I will have to run all the 10 yards.
Thanks
Old 01-14-10, 01:08 PM
bacaudio
bacaudio's Avatar
I just recently did this on my LS400. It is very time consuming but as far as hard labor I have been up against worse. You are right this is the best way to get the crank shaft pulley off. It worked great! Be prepared to spend some cash though. I get discounts at my local store and still spent over 400 bucks on items that were shot when I dug in there. Pulleys will most likely need to be replaced gaskets and things. Way worth it though!
Old 02-03-10, 06:16 AM
PEARL2
PEARL2's Avatar
lexls. tutorial info is good stuff. I ran into a problem. Step 33, my crankshaft does not have any white mark to start with. It have a " U " ingraved in the metal. I have a pic posted in the performance and maintenance section. should i use this to set the timing or should this mark be at 12, 3, or 6 o'clock.
imherenow
05-20-11 03:43 PM
iman61701
10-26-10 03:42 PM
beausimon
Maintenance
04-24-07 02:04 AM
skippy911
RX - 1st Gen (1999-2003)
01-28-07 07:23 PM
LEX012006
12-22-06 07:38 PM
Quick Reply: Change Water Pump on SC 400 without messing with the timing belt
