My 1J running
My 1J running
So.. i got the1j running, simple swap, not so simple wiring.
the Details
Time.. 4 days
2 16 hour days
i spend 1.5 16 hour day wiring it,
the rest was prep.
as for wiring, i did cut the co ax cable, all 8 or so of them. i rewrapped them with braided stainless steel, all heat shrinked
every single connection was solidered, even the coax.
every connection tested.
i did make it about 24" instead of 18, erroring on side of long rather than short... it is infact too long
tools used for wiring
10 gauge wiring, 2 feet
12 gauge, about 10 feet
stainless steel braid.. about 16-18 ft
18 gauge, 200 ft!
strippers
1.5 lighters
a whole **** load of heatshrink
1 soildering tip
2 small tubes of rosin core, after that i bought the 1/4 pound roll
tools for engine
ALL
also a walbro. i bought a carter HP pump and a walbro 255 came inside
it was pretty unevent full
i forgot to put the radiator draincock in i asked my gf to get it, she "accidentally" kicked a whole open gallon of antiifreeze in my face!
fingers ravaged, body tiired, but worth it to hear it growl!
and eveyone says "wire up the neutral" but noone says how
you can actually start it through the neutral safety.
need to put the face back on, need to get the exhaust redone to accomidate the new engine.
first start up. i prime the fuel pump
http://www.youtube.com/watch?v=g8Rv56HvMvs
revving the 1j after a little warmup
http://www.youtube.com/watch?v=eibVQ1gONzI
the Details
Time.. 4 days
2 16 hour days
the rest was prep.
18 gauge, 200 ft!
strippers
1.5 lighters
1 soildering tip
tools for engine
ALL
there are a **** load of coax cables. i think 4 and 2 groups of wire that are sheilded. if i had to do it again and read " dont cut the coax" cut them at the end where they connect to the ecu. dont hack half way into it like i did. the heater valve wires needs to be lengthened too.
So i took it for a spin today, sans hood and exhaust... OMFG. This much power is refukindiclious. i run the w58 STAGE4 , it spun them all the way through 2nd. not chirped 2nd, spun all the way. back end breaking loose. you know i felt? the way that guy screams in the lexus is commerical
IS COMMERICAL
IS COMMERICAL
ok so an update, it's all stock up front, only a 3" dp back, apexi black turbo n1. even stock restrictive *** box
dynod!
run one , exhaust with silencer stock boost 9.26
max whp 246.26 max tq 268.52
run 2, open 3" stock boost 9.26
max whp 265.51 max tq 268.83
suprisingly the tq kicks in way earlier on the corked one
everyone even me was surprise by the power and it ran super rich after 4k rpms
dynod!
i think around 14. also i was told i could pick up upwards of 15whp because of how rich it was, the dyno doesnt read lower than 10 points on the air fuel ratio. so i need to install the afc and get it retuned
Retroplay
09-14-15 04:21 AM
