How can you tell which psi spring is really in the wastegate?
Old 01-16-10, 10:45 AM
ashtray
ashtray's Avatar
Default How can you tell which psi spring is really in the wastegate?
My wastegate is an OBXRacing and it said that it came with the 8.** psi spring in it and that the other 2 colors(they are the same damn color) were 14 and 17. Now one of the 2 is super soft and easy to compact with my hands..then again ive got huge hands. But yea back to the question..How can i know for sure which psi spring ive got in the wastegate? Thanks in advance to anyone who chimes in on this.
edit: i just found out it came with a 14psi spring in it.
Ashtray-
Old 01-16-10, 01:34 PM
mptjimmy
mptjimmy's Avatar
you can put positive pressure via a small pump and see when the wastegate opens
Old 01-16-10, 04:11 PM
CP_Ree
CP_Ree's Avatar
^^ you can try that if you've got some way to hook it up to compressed air w/ a gauge too. Otherwise, I'd try calling the company who made it for clarification of the spring colors.
Old 01-16-10, 07:52 PM
ashtray
ashtray's Avatar
I just checked the receipt and i clarified for myself that it comes with a 14.75ish psi spring in it and then of the 2 i have to play with, one is super hard and the other is super soft so its obvious which the 8.75ish one and thats the one i need.
P.S. to take the wastegate apart to change springs, i remove all of the hexagonal screws or octagonal around the wastegate then the top one with the vacuum fitting right?
Old 01-18-10, 08:03 PM
Holtspeed
Holtspeed's Avatar
Ashtray-
What style obxr did you get?
Old 01-18-10, 09:47 PM
ashtray
ashtray's Avatar
this exact one
http://cgi.ebay.com/ebaymotors/OBX-R...Q5fAccessories
Old 02-11-10, 10:39 PM
turbodremz
turbodremz's Avatar
dont worry about all of that, I know which ones are which, and how to swap them out..Ill learn ya when its time
Old 02-12-10, 12:57 AM
MongooseGA
MongooseGA's Avatar
Just do the install. Measure the spring rates by the seat of your pants
Old 02-12-10, 01:09 AM
turbodremz
turbodremz's Avatar
or by how quickly the pistons melt? or the HG blows? I dont think he would like that too much..he has the same WG I do, and I know which ones are which..
V.I.P.
Suspension and Brakes
06-26-07 09:58 PM
MrJohnE
Southeast
03-22-06 04:41 PM
Quick Reply: How can you tell which psi spring is really in the wastegate?
