Difference between SC400 tranny and LS400 tranny?
Old 01-23-10, 02:53 PM
lev00221
lev00221's Avatar
Default Difference between SC400 tranny and LS400 tranny?
Hello everyone,
I am the fortunate owner of both an LS400 VVTi 5spd auto and an SC400 VVTi 5spd auto. However, the LS400 seems to have more power from takeoff then the SC400. Is this because of different gearing in the transmission? The respective transmissions have different part numbers and thus I am assuming that the gearing is different. The torque converters have the same part numbers. Is it simply different tuning of the same mechanicals? Has anyone ever tried and LS400 transmission in an SC400?
Thanks in advance for your time.
Luis
Old 01-23-10, 03:40 PM
MarcusMIA
MarcusMIA's Avatar
The VVTi came with a 5 speed auto?
Old 01-23-10, 10:33 PM
willhickey
willhickey's Avatar
i remember seeing a discussion about this on lextreme a couple days ago you could maybe check there
Old 02-07-10, 10:21 PM
lev00221
lev00221's Avatar
Anyone have any insight into the difference between these transmissions?
Old 02-07-10, 10:40 PM
potatoBBQ
potatoBBQ's Avatar
If I'm not mistaken, both the LS400 VVTi and SC400 VVTi use the same A650E transmission w/ the same gear ratios.
Old 02-10-10, 09:15 AM
1995Lexusc
1995Lexusc's Avatar
different gear ratios
Old 02-10-10, 09:44 PM
93sc3005sp
93sc3005sp's Avatar
probly different rear end gears, the 98+ sc400 came with the 3.26 gears which i have swapped in my sc3, from what i understand the ls400 has 3.62 gear ratio, but it could have been changed on the vvti models
Old 02-11-10, 06:23 PM
v8soarer91
v8soarer91's Avatar
different valve bodies, torque converter, 1st gear ratio.
about the only thing the same is the trans casing and pan
Old 07-27-10, 09:04 PM
megamax
megamax's Avatar
^^^ is this true??(can someone chime in here) i have a deal on a LS400 early 90 ish transmission.
i was going to use it for my SC400 1994. is this a bolt up affair?? of are they totally different??
92lsondubs
06-27-19 02:27 PM
Returd
06-28-17 06:36 AM
KrazeMatik
11-17-07 07:46 PM
KrazeMatik
08-04-07 12:41 PM
soarer808
SC400 / 300 Classifieds
10-16-05 07:27 AM
Quick Reply: Difference between SC400 tranny and LS400 tranny?
