S.O.S. to all sc400 owners
#31
this is an interesting thread and also you have a very nice looking car 718murdoc.
I've taken my car to a shop that i really trust and then had my own personal mechanic look my car.
They both said that the car is running perfectly normal and nothing is wrong with it. Although i dont buy that because i've been having hesitation issues and rough idling. So what i did was change the spark plugs and did a quick wipe in the throttle body. After that, i take the car for a spin and just like that the car rides smooth. Now its back to acting up again and im not sure what it could be. I thought maybe throttle body but i just dont think thats the case. How can i check if the ECU is good or not?
#32
Thanks Murdoc. I still havnt gotten around to checking what is going on with my car but now im really suspecting that it could be either distributor caps or ignition coils. We'll see.
#33
So its been a while since ive been on this forum. Up until this point my car was running fine with periodic maintenance, but now the bad idle is back. My mechanic and i agree the iacv needs to be replaced; i got 2 used iacv's and they both performed badly. The idle surges then drops, i want a brand new iacv but the Lexus dealer says that part for the 92-94 Lexus SC400 is discontinued. Now what? The so called good units online are a gamble. What can i do if a new part is no longer being made?
#34
#35
#36
#37
I think you need to re describe whats going on, maybe with a video. It can be lots of things.
Is the idle just sometimes high, and then sometimes low? or is it constantly swinging between the 2 every few seconds.
If it is constantly swinging, then the idle valve is probabaly ok, that is what the ecu uses to adjust the idle.
So if it wasn't working, the ecu would not be able to swing the idle 1200 rpms which is really quite alot.
I would look into the tps then as when the tps is bad or in the wrong position, it swings the idle exactly like that.
Anyone who works on toyotas knows that.. including the 2 people who posted in post 13 and post 16 who literally said it solved their exact same problem.
For some reason everyone just skipped over what they said.
Almost every mechanic who has no idea what they are doing fiddles with the tps and leaves it in the wrong position.
I would assume that is the kind of mechanic who would claim they do and say stupid stuff like the power isn't being distributed correctly.
The stock ecu is super sensitive to tps position. you can try loosening the 2 screws and turning it some to see if it stops doing it, or even just unplug the tps.
It could also be the fuel ecu or the main ecu having issues, both are known to go bad from time to time, but it 99% sounds like your tps.
If sometimes it is high, and sometimes it is low, without any swinging back and forth every few seconds, then yes a bad iacv could be the issue or an ignition component.
Your engine has 2 ignitors, 2 coils, 2 rotors and caps, and 8 plug wires, 2 coil wires and 8 plugs. just changing plugs and plug wires is not a full tune up on this engine.
#38
mgmprofits
Performance & Maintenance
11-24-13 03:26 AM
