What is the matter with my car!
I cannot get my damn car to stay on, I did the 12v mod, I bought a new fuel pump, I changed all the fuses, all I can think is that the ecu has bad. The fuel pump doesnt come on all the time and never stays on longer than 10 minutes, I seriously can't figure this **** out, any ideas will be greatly apperciated.
hmmm...that hit a stopping point for my thinking cause im not familiar with the map ecu..but with the fuel pump cutting out or just not coming on at all sounds like a bad connection or an ecu problem. when you did the 12v mod you did solder the wire correct? and for the occasional 10 minutes that it does run, how does it idle?
i have ran ME2. the only thing ic an think of is that when it warms up it then hits a cel that is either super rich or super lean, making it lean out and turn off. who tuned it. do you have a wideband? send me your map i will take a look at it. im having a hard time understanding what is really going on with your car. it turns off then wont start? or turns off then starts?, or all of the sudden the fuel pump just stops getting power?. try wiggling wires at the ECU and tapping on it.
1siksc
I was thinking about going this route, I just want to be sure it's not an ecu issue first.
