2jz / sc400 swap guide
I'm still curious as to why people on this fourm don't seem to do things themselves - granted I know some of it comes down to a facility to do it,...but wouldn't you rather know that You did it - and if anything goes wrong -YOU know where to look?
Wiring can't be that hard - and I can't see spending $500-$800 on a wiring job that should essentially plug in for the most part.DR tweak seems like he does great work but man - $800 could Be 2/3 of a Turbo Upgrade.
I hate Buying SOMEONE elses problems so I'd hate to know someone else worked on my car or whatever and Fixing all their Mess-ups if there are any.
Maybe I'm crazy but I will leave it at that - Good luck w/ your swap - I'm right behind ya,though 1JZ single Turbo 5speed here.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Ace9282 : A few question for you. Is this a JDM or USDM motor? Is it from an Aristo or Supra? Just asking because if it's from an Aristo the upper & Lower oil pan would need to be swapped with an SC300 Upper & Lower oil Pan. The only other thing that would need to be swapped or modified would be the lines to the rack different location. On the SC300 no change or modification is needed. The wire harness would need repinng and your good to go. Also there are two Supra TT MKIV motor mounts and brackets. A long & a Short. Check with GuickGS300 for the part number.
i just put a '95 2jzGE (rebuilt by me) in my 92 sc400 and there are several differences that have already been mentioned here. i have a haltech platinum2000 EMS, so i didnt have to deal with the wiring crap nearly as much, but:
motor mounts are slightly different
fuel lines are different (but i made mine work)
i didnt have a starting harness, and my charging harness was of the wrong year (95 instead of my 92 chassis)
i'm also using the sc400 driveshaft, but i had to have my W58 yoke welded onto the sc400 auto shaft (cost 98 bucks locally)
