how much is this setup worth?
Guest
Posts: n/a
A local guy from sf forums is selling his 1jz here's the specs.
1jz engine with all new seals and gaskets from toyota including front and rear main seals, intake and exhaust, cam seals, head gasket, and valve cover gaskets.it has arp head bolts that have already been re-toruqued at 90. it has 2jz cams installed as well as mkiv 550 injectors. the wiring harness is already extended with new connector going to he coil pack as well as knock sensors. this setup will include all sensors as well as 2jz map sensor and ignitor.
note that the harness is made for 89-92 supras.
he took me for a ride in his car and it pulls pretty hard with his masterpower turbo on it and everything seem to work and sounded perfect
He told me he wants 1600 for the complete engine and turbo manifold.
"turbo is not included everything but that he will be using it in a 2jz swap"
Guest
Posts: n/a
if he knows what he is doing then it sounds like a good deal but be sure he knows what he is talking about and not just making it seem easier than it is gl
Guest
Posts: n/a
he told me it needed a valve or cam job lol i forget what it was but it was because the 2jzcams so i think i was meaning to say cam job either way i dont know what they mean but when i looked at the engine it was not even ticking or at lease not any ticking i could notice i don't mind it at all it seem normal and healthy.
