MAF Translator Pro..
Ok before we get into this too much, I know its another piggy back, but its going to be some time before I can get my hands on an AEM unit, and Im selling my current setup soon, but need my car back on the road..
So I have been looking in the MAF Translator Pro or GEN2 (http://www.maftpro.com/) mainly cause it seems to have more features than the Greddy EMU, SAFC (2 or NEO), and I can still go to a map setup, and not spend $600 for a black chrome box and CD and still need to make the harness![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Does anyone have experience with the MAFT-Pro on an na-t SC/Supra. If so how did you like it (not comparing to a standalone), ease of use, data loggin, AFR tracking, etc..
any input on it would be great, cause if its worth it, it may be ordered at the end of the week and be ready for the rest of the new parts.
All I have heard so far is is that its basically an advanced SAFC controller that has the option to convert to map, the Gen2 and Pro allows and "auto tuning" function similar to the Greddy EMU which will basically set itself when paired with a wideband o2. But I dont think the Gen2 allows a speed density conversion.
So I am going to give it a shot, and order the MAFT Pro and convert to MAP using a 3 bar map sensor and hopefully all goes well
I've been using it for two + years now on my supercharged SC400. Haven't blown anything up yet!
About 12psi, stock motor, stock timing running speed density with a GM 3bar and IAT (NO MAF).
Tuning is pretty easy. You can make custom VE tables if you want. The auto AFR works well for boost, never really got it to work well for normal driving.
KC
KC
KC
KC
Absolutely wonderful, thank you! How hard was it to convert the wiring from MAF to map?
It can also be used to modify the MAF signal like any other piggy back. Changes the MAF out signal based on the MAF in signal and your settings.
There is also a "hybrid" mode which I've never played with. I assume it somehow uses the MAF signal along with the MAP signal.
KC
Ok still a little more messing with setting to get it 100% correct, but I started the car up today with the MAFT Pro installed, and the MAF removed, and all I can say is wow, what a difference.
The build is still in the first stages, but a video should be up in a few weeks once everything is set and running 100%
