NA-T -- Is it worth the trouble?
#122
$2649 VS $800 <----BULL**** #. USE THE SEARCH BUTTON AND RESEARCH THE 1J SWAPS.
...or if you feel like popping your engine out and have the $/means to do it listen to this guy...or look at my build. I dropped buku bucks on an na-t setup and wouldn't have batted an eyelash at pulling the motor if I thought the 1jz would provide me with a.)less headache or b.)a better platform. For your needs- you could def go 1j and be pretty happy with it however comma it will cost you a lot more than what this dude says. I read back and your first post said you're looking for 250-300hp. But I could be wrong...I'm a girl and I basically know nothing about cars.
How can you tell me I need to research a 1J swap, If i just finished the damn swap...
ignorance is bliss...
#123
Thanks Hyjaxx. And yes, I am indeed getting the sense of where I want to go with my project, including simply getting a 2002 6-speed f-body with 300-320hp at the flywheel bone stock.
#124
Out of everything I said it kills me that you're raging over the one thing NOT directed at you.
#125
Numerous SC300 owners have told me that NA-T is a nightmare. And pure empirical evidence -- i.e., the fact that too many NA-T people rip out their kits and sell them on this board and others -- does appear to support the notion that NA-T may not be ultimately desirable. In other words, if NA-T was that great, why are so many later taking it off of the car?
Then there's the people who blow their stock motors doing NA-T. I've personally seen a local guy blow at least 3 motors because he doesn't have the right tuning parts or turns boost up too much.
EDIT: I think people assume that because it is a JZ motor they dont need the best tune possible and can do it themselves with a piggyback.
1JZ is a great motor, but you need to realize the limitations of the stock setup.
1. 370cc injectors= You don't want to max these injectors out, so to be safe you should upgrade the injectors for anything more than 330whp to remain near the 80% duty cycle range.
2. Stock injectors are high impedance= high imp injectors aren't cheap. So you either buy the GTE resistor box, wire it in, buy a fuel rail so you can use low inp. injectors which are more readliy available than high imp injectors.
OR you spend about the same total money on some high impedance injectors(usually orered from Japan in larger sizes) which aren't as readily available..boils down to your cost and what your comfortable using. Is it PnP?..etc
3. Stock jdm turbos= ceramic wheels, which have been known to go bad above 14psi depending on how they were treated in their previous life. Some people use the JDM turbos at 17psi daily as well though...it all depends on how they were treated.
I'm not trying to talk you out of the 1JZ swap because it'll do exactly what you stated your goals are.
