NA-T -- Is it worth the trouble?
Guys,
I have a 1995 SC300 manual 5-speed with about 120K on the clock. Recently got the car and was thinking about boosting it. My objective was to achieve about 250-300 rwhp with low boost (e.g., 5-6 psi) while retaining daily drivability.
Numerous SC300 owners have told me that NA-T is a nightmare. And pure empirical evidence -- i.e., the fact that too many NA-T people rip out their kits and sell them on this board and others -- does appear to support the notion that NA-T may not be ultimately desirable. In other words, if NA-T was that great, why are so many later taking it off of the car?
So, how many here have NA-T kits installed and are satisfied with the resulting performance and refinement? Please share with us your own personal experience concerning your NA-T.
You should be fine. do a compression test before any install. Keep the boost low, make sure you have all the crucial components and dont cheap skate on parts and make sure its all done by someone who knows their crap. Good luck. i hope someone else can help you more.
edit: notice my sig. once im installed in about 2 weeks...ill like you know lol
the reason why so many na-t's become scrapped projects is because the majority of people that go na-t do so because they think it is the cheap route. Meaning they're the ones looking for cheap (cheaper) parts... such as piggyback ecu's, ebay manifolds etc. I'm not saying you can't get a running car with discounted parts, but modding sc's will never be cheap... if you want it done properly. If you don't have the cash to bust out find a different car. I'm not trying to be a ****, its just true, there are many other cars where boost comes easy and cheap. Like the guy above me said... with na-t its all about the tune. I've got 10k+ alone in just my na-t setup right now (drivetrain only) that included about 2 full days with justin nenni getting the car to run like a stock car from the factory on stock compression for maximum peppiness while making 400rwhp and 400rwt... Na-t is worth it if you've got the time and money.... but i would say that gte swap is a faster way for most people... and the fact is that a gte swap is just that, its a swap. You're taking a complete system from one car and moving it into an extraordinarily similar chassis... there is not much engineering involved. With an na-t setup... you are changing the function and design of the engine under your hood... If you put in the ****load of time, money, research and effort to do that properly then yeah its worth it. But if that sounds daunting... which it is... then just gte swap it.
na-t imo is def worth it
for the amount of power you are looking for .. on stock compression , decent manifold , a small 61mm or 60-1 turbo and a aem ( you must go standalone for na-t to work better then stock) you could run 10 -12psi all day long with no concerns and make close to 400rwhp
a cleansc down here runs 14psi all day with his na-t and has been for over 4yrs strong and has never ever opened up his motor and makes about 440rwhp
look at my sig , my na-t setup with stock pistons , headgasket and arp head bolts ( and ttc cams) just did 561@21psi on pump and my car has been running strong sonce 11/07 again stock bottomend
gte setup is doable but be not decieved.. costs do add up quickly in doing the swap and to end up with about 350ish rwhp imo isnt worth it
2000 for motor
800 wiring harness
misc parts needed to swap over from aristo motor to make it work 900
bov 200
fuel cut defender/bcc 200
front mount 400
piping 400
some piggyback /tune 500
labor to perform swap (if not putting the wrench time in) at least 1500
total est approx +/- = $6900
na-t
manifold 400
turbo 650
intercooler for your power needs 400
piping
wastegate /bov 400
oilfeed/return kit 250
downpipe/midpipe 350
aem +tuning 1600
misc items 400
labor to install 800 maybe
under 5k total
and with this platform you can upgrade alot cheaper with turbo and fuel as needed
2000 for motor
800 wiring harness
bov 200
front mount 400
piping 400
na-t
manifold 400
turbo 650
piping
wastegate /bov 400
aem +tuning 1600
misc items 400
under 5k total
Ashtray,
What exhaust manifold are you using? Are you using a kit or did you put together the parts by piecing them together?
na-t
manifold 400
turbo 650
piping
wastegate /bov 400
aem +tuning 1600
misc items 400
under 5k total
na-t
manifold 400
turbo 650
piping
wastegate /bov 400
aem +tuning 1600
misc items 400
under 5k total
What small turbo (either 57mm or 61mm) and manifold do you recommend for best fitment and performance? Also what piping kit is best for fitment?
I am currently working on putting a NA-t together. I sold my motor and trans out of the SC that I currently have and am planning on having fun with some NA-t power. It will definatly be AEM EMS. That is one thing I will not spare money on. I am really excited and I am shooting for 500-600rwhp
I'm a proponent of GTE swaps myself, especially on OBD1 vehicles. The quality of NA-T really does come down to tuning. I've been in properly tuned NA-Ts and ****ty tuned NA-Ts. Big difference. Beauty about swapping to GTE is the ability to institute a proper baseline on factory tune which makes upgrades much much easier.
If you're OBD2, well, then you're stuck with NA-T (there are options for GTE on OBD2 but pricey).
