5speed sc300 with stock twins from supra
hey im new here an i just got my 93 sc300 5speed. i was lookin to try to put stock twins from a supra. im just tryin to find out what all i need to make the car run right.
if you are using your stock motor in your 93 .. you want single turbo not the twins. if so http://www.clubna-t.com/ will help you out alot getting a turbo kit and all. your stock 5sp tranny will only handle about 300-350rwhp. have fun and good luck
That's a really clean car, I suggest you search up your options, and read above
Or if you want to swap.. that's pretty expensive for the 2jz, most people go for the 1jz.. 2jz-gte i mean..
There are several NA-T kits. XS Power is one and BoostLogic is another just off the top of my head. Both projects are costly and time consuming. Depends on what you want...a GTE motor swap, or keep the engine you have and turboing it. Me personally, i wanted to keep the original GE motor and just turbo it.
