Where can I get the hose for leaking power steering? Also alternater question.
If I understand correctly, the problem with the SCs is a leaking power steering hose and not the power steering assembly itself, right? Where can I get the hose?
Also, the Alternator; Anyone know of a dealer that distributes them? Does anyone know if the part is also used for Toyota because maybe it would be a good idea to get it from Toyota.
Essentially I need some help with getting an Alternator and repairing the leaking power steering or else it would not be worth replacing the alternator.
Thanks a lot.
EDIT: I think I heard about Carson Toyota distributing the alternator or is that just the 1JZ and 2JZ?
Thanks a lot.
drift motion has a nice braided power steering line that replaces the leaky stock one, and its pretty cheap too. i just replaced mine with theirs and it looks and feels great.
remove your factory hose and take it to a specialty hose shop in your area. theyll build you a braided hose with your factory ends or find you new replacement ends. it should end up being around $50 or so
DshngDaryl
03-23-20 10:40 AM
