help engine code dtc13
ok so both cam sensors have been replaced. the crank sensor replaced. the spark plugs and wires replaced. the air filter replaced. And still i get the code coming up and it only happens when the engine gets warmed up. what ever it is has gone from the light comes on then goes off to it just stays on. My exaust tips get so hot now they have went from gold to purple so I am wondering if it is my timing belt
oh and on my way back from cali to reno my exaust got so hot all the crap inside it started to burn and left a cloud of smoke behind me to the point you could see nothing no cars no trees nada
i had the same problem check Ignition rotors. i check everything ignition igniter,
i check power and ground to pcm module the only thing that came in mind was
ignition rotors i replace them and no more problem.
