help engine code dtc13
Old 02-16-10, 03:35 PM
infiniti24
infiniti24's Avatar
Default help engine code dtc13
i know its a RPM code but what dose it mean? thnx in advance
Old 02-16-10, 03:38 PM
LiCelsior
Retired
LiCelsior's Avatar
cam position sensors are bad, crank position sensor is bad, or timing is off.
Old 02-16-10, 03:45 PM
infiniti24
infiniti24's Avatar
timing was done about 15K ago so not that
is there a way to tell if its the cam or crank and on what bank?
Old 02-16-10, 03:49 PM
LiCelsior
Retired
LiCelsior's Avatar
check the resistance and see if its in spec.
Old 02-16-10, 04:05 PM
infiniti24
infiniti24's Avatar
okay cool not to spoon feed myself here but dose any one have a diagram or the general area I will find the 2
Old 02-16-10, 04:11 PM
luvmyaussy
luvmyaussy's Avatar
What year?
Old 02-16-10, 04:24 PM
infiniti24
infiniti24's Avatar
1994 sc400
Old 02-16-10, 04:42 PM
luvmyaussy
luvmyaussy's Avatar
Sent you a pm
Old 02-16-10, 06:31 PM
xxtoobsxx
xxtoobsxx's Avatar
Happened to me, my pass side cam sensor pickup. Check for resistance, I believe that should help. I drove with it for like a year. On cold nights it would go away!
Old 02-16-10, 06:47 PM
infiniti24
infiniti24's Avatar
tank tey lord the sensors or right there on the top vs in some hole that takes 9 hrs to get to
Old 02-16-10, 08:46 PM
LiCelsior
Retired
LiCelsior's Avatar
still gotta get to the distributor housing to replace it lol.
Old 02-18-10, 12:44 AM
infiniti24
infiniti24's Avatar
on the crank right? the cams are on top
Old 03-03-10, 10:47 PM
infiniti24
infiniti24's Avatar
ahh i know what you mean now its not the greatest place. well the resistance is in spec so I'm hoping it goes away with the bad tranny being rebuilt....... i doubt it though wheres the crank sensor?
Old 03-03-10, 11:07 PM
LiCelsior
Retired
LiCelsior's Avatar
next to the crank pulley..if u look on the side of the pulley, you'll see a connector.
Old 03-05-10, 10:11 PM
infiniti24
infiniti24's Avatar
sweet thnx
Quick Reply: help engine code dtc13
