Please Help! Oil Lamp Light
i have a 1992 SC300 just did a motor swap (stock 2j) and blocked off EGR. My oil lamp light (the yellow one w/ a wavy line underneath) just went off. i called the dealer and they said that its the 'low oil pressure' indicator, and not to drive it until its fixed. i did an oil and filter change to see if this would help- did not... has anyone experienced this problem? Any suggestions? Im trying to get an OBD I code reader but until that happens can you guys recommend a checklist? Thanks in advance.
**Update!**
I just ran diagnostics on the car got the code (DTC: 21 H02S Front Circuit). I googled it and came across this website:http://www.iequus.com/downloads/manu..._E_14JAN03.pdf.... however the code reader did not say anything about the "low oil pressure light?"
Also has anyone had experience with DTC 21? The description according to the site is: HO2S front circuit, HO2S sensor/ heater or circuit... Im open to any/all suggestions, thanks guys!
**Update!**
check the oil level, my stock motor has leaking Valve steam seals so it burns oil, sear vss problem and its a know issue, my car burns about 1 qt for 1500 miles... runs stron..but i need to add oil every now and then
OK, ill be sure to monitor my oil level... i just did oil/ filter change too! thanks
I remember the oil pressure sending unit was a cheap part. You can replace it, but I dont know if that's the fix. If oil level is good and the oil pressure light is still on, then there may be another problem. You're not gonna get any CEL codes from the OBD1 reader
gl with the repair
bump so someone else can chime in
gl with the repair
gl with the repair
gl with the repair
