1jzgte auto greddy bcc install
hey, iv been searching can only find the installs for 2jzgte ecus. i need to know the pinouts i need to tap into or the greddy bcc that has 4 wires:
black - ground
white - map sensor- away from ecu minty green wire
red - power
green - map sensor - on ecu
any diagrams on location of these?
https://www.clublexus.com/forums/per...c-and-scc.html
this is the only 1jzgte pinout i can find. but i dont see a tps or turbo pressure sender listed. please help!
black - ground
red - power
i hooked it all up and now i have a cel and the car cant idle for crap. which do i hook up to for the map sensor?
VCC
VT1
PM
i hooked it to the vcc. but im thinking its the pm now
edit: its PM that its supposed to go to. its a minty green / black stripped wire. im uploading an amazing pinout.
VCC
VT1
PM
![](http://i143.photobucket.com/albums/r144/enot767/bccinstall-1.jpg)
http://i143.photobucket.com/albums/r...ccinstall-1.jp
once hooked up, grab your favorite multimeter and put your negative lead on something metal, and your red lead on the minty green wire on the ECU side. this will give you a voltage. unscrew the 4 screws on the BCC and you'll see a screw (if you dont see a small screw inside and its already at 4.3v then your okay) turn this screw until your multimeter reads 4.3v
please refer to this pinout:
![](http://i143.photobucket.com/albums/r144/enot767/JZZ30_1JZ_AUTO_ECU_PINOUT.jpg)
http://i143.photobucket.com/albums/r...ECU_PINOUT.jpg
Your welcome.
CatManD3W
SC400 / 300 Classifieds
05-26-15 07:56 AM
