Soarer 1jz swap for me!!!!
#47
Here you go for your cable need a adjuster:
Supra TT throttle cable
-this is because the stock cable is too short and 1jz cable is too long.
-you still need to adjust bracket to get this to work
-Part Number: 78180-1b090
www.toyotaworld.com
http://www.l-tunedparts.com/index.php - Ask for Steve Ganz
#48
You can use 92 corolla TB cable it's almost the same size as the TT one.
Ok the corolla is better than the 4 cylinder camry,i think the v6 camry is about the same size as the corolla or a little shorter.
The 4 cylinder camry is about 33 inches from the TB to the point where i bolt to the firewall.
The 2jzge is 17 inches.
The corolla is 23 inches.
But i will measure the v6 camry tomorrow.
![](http://i99.photobucket.com/albums/l316/ogs5989/021-1.jpg)
![](http://i99.photobucket.com/albums/l316/ogs5989/022-1.jpg)
Camy TB cable
![](http://i99.photobucket.com/albums/l316/ogs5989/025.jpg)
![](http://i99.photobucket.com/albums/l316/ogs5989/026-2.jpg)
This the camry TB cable long as hell
Camy TB cable
![](http://i99.photobucket.com/albums/l316/ogs5989/007-5.jpg)
#49
Nice work man. I'll be doing this swap also in my 94 when my motor comes next week. Did you happen to change out the front main and rear main seal? And did you change out any of the gaskets and valve stem seals? Also how many miles were on your 1jz when you bought it? I got mine for 1.1k and its got 36k miles. Comes with single turbo. Let me know also what TB cable you use cause i didn't even think about the tb cable.
#52
Camy TB cable
Camy TB cable
#53
yea its running really good now, just have to fix the KS wire so it will stop retarding the timing, but it pulls harder than my supercharged maxima, weird. i fixed all the leaks (PS/trans cooler hose)
i even got bored and and buffed out my headlights and installed HIDs
![](http://i658.photobucket.com/albums/uu310/jamaicanlovrboy/photo.jpg)
replaced my needles, but i need to get new led bulbs
![](http://i658.photobucket.com/albums/uu310/jamaicanlovrboy/sccluster.jpg)
#56
yea man the steering wheel is tore up, im looking for one...yea it is very fun, plus my car has no exhaust, nothing to let people even think its turbo, so i surprised a WRX a couple days ago, he had exhaust, not sure what else. i was waiting for him to catch back up so we could go again, but he stayed behind
#58
ok i have a question, when i do WOT pulls, the car stutters as if fuel is getting cut, could this be due the fact that my knock sensor wire is messed up, and im getting a KS code?.
#59
Is it stuttering at max boost, I don't remember if you have a boost guage or not, if so check and see it stutters at around 8-10psi, if so it the ecu employing boostcut. Because I remember you saying that you didn't raise the boost. You will need to get a Boost Cut defender to aleviate the problem.
#60
Nice Swap bro. Job well done. But I am having the issue of when i squeeze my car while on the highway and getting up in speeds the check engine light comes on... But the car is perfectly fine... When yhou turn the car off and turn it back on the light goes right away. Very weird i know...
BTW I do have a speed cut or Boost cut defender at all... I still have my stock side mount on the car.
