Soarer 1jz swap for me!!!!
#76
also do u have a wideband??
i wanna wire my bcc n scc in but im scared cuz i dont have a wideband or boost controller, and if im hittin boost cut now at 14psi then i kno im boosting more then 14psi....
I dont kno my air/fuel ratio so thats y im scared, dont wanna pop my twins or motor
#77
Thats Cool, i never heard of the AFC NEO doing that but, how are ur twins holding up wit the 14psi??
I do have a wideband, but I also have an exhaust leak between the rear turbo and the dp. So I still need to take that apart and seal that back up. Right now my AFR's are pretty inconsistent, but hopefully they'll read normal when it's all sealed up again.
#78
The twins are doing fine so far. They've been at 14psi for a little over a year now. I kind of baby my car though. I always let it warm up and cool down properly, and I only ever beat on it when I'm at the track. I've had the swap for a little over two years now, and around 45k miles (the engine is now at ~145k) and it's still holding up fine with the exception of leaky valve cover gaskets and a coolant leak near the upper water neck.
ima jus put the bcc & scc in and make sure it works then not beat on the car i guess until i get my wideband...
But no smoke at all from the exhaust...like i see i get alil smoke when i rev the car sometimes or when im coming to a light i downshift n might see some...im wondering is it cuz my twins are takin a dump or wut???
#80
just a little video i recorded today..there is abit of delay in the video though, but you get the idea
http://www.youtube.com/watch?v=swF8e0ejAMM
