Soarer 1jz swap for me!!!!
hello everyone. just picked up my engine on saturday, decided to share some pix. Engine looks to be in great shape, compression test looks good, was from 100-150 on each cylinder. I even got a 3" downpipe while i was picking up the motor.
the motor, trans and soarer ecu
dip stick, oil looks clean
ok shot with the oil cap off
real soarer ECU
and finally, the downpipe
real soarer ECU
well when the engine been sitting, and you try to jump the start and get a comp reading number, it will read low, when its hot, they should go up, so for right now its good, but when it gets installed, those numbers should higher. the good thing is all the numbers are pretty much even, which is what im going off utill i get it in the car. if one was bad, it would be significantly lower than the others.
The motor seem like it was maintained, WP, and TB replaced, no valve cover gasket leaks, compressor looks new as well, trans oil was still red, so i just wait and see
we its just supply and demand. the guy told me he sells more honda b18, b16, h22, so they cost more than a 1jz. see its my DD and i have to contend with traffic, so i wanted an auto. wont be as fun, or put down as much HP, but it will be ok for me, i only want 300whp
