Supercharged SC400 - lighting M112 - with air/water intercooler
Replaced my M90 setup with the M112. WIth the smallest pulley on the M90 I could only get 6psi. I hope to be able to run at least 15 out of the M112.
Custom upper intake manifold utilizing stock lowers. Using modified heater core for intercooler core. Then an M112 from a 2002 ford lighting. Air gets sucked in through a custom intake plenum. A Q45 throttle body is used to get in that extra needed air.
ECU has been replaced with AEM 1100 out of a 2J. Igniters have been replaced with two factory 2JZGE igniters. This only required a dremel to cut off the alignment pins of the connector.
Injectors are 440cc injectors from 7M, but will be upgraded to 550's or 680's
Running E85 ethanol for fuel
First vid of the new setup
http://www.youtube.com/watch?v=1rE9CWHeAB8
I calculate I can get around 450rwhp with 680's. Pushing an M112 past that is extremely difficult. I might go twin screw after a bit, and at that point then 800cc+ would be needed.
That was because the map sensor got disconnected. I usually runs pretty smooth.
And updates, really nothing right now. I have had 3 other projects that have had to take priority. For instance I am working on a 1UZ swapped 4runner
