What turbo should i go with???
Ok well my stock twins are going out and i was doing some research on single turbo set ups but im on a budget i was wondering what you guys think or have experienced with your single set-ups i want a quick spool but then im on a $600 budget on the turbo i have the manifold and the apex safc and down-pipe already ect... but now i need the turbo what size do you guys recommend to me....i had this company in mind..... heres the link
http://stores.ebay.com/High-Performa...subZ1102149018
With turbos, you get what u pay for, it wont perform the way you want it if you go with a cheap turbo. I have a precision turbo.
Go with Garrett, turbonetics, precision, greddy or HKS....
A quick spooling turbo will be a good ball bearing turbo. I currently have a T67 Dual ball bearing turbo i paid 1100 for it and its AMAZING< i have full boost at 3200 rpms.....what more can u ask for!
I have a master power T70 on my car, it's a decent turbo, but it smokes even with out blown seals, I think it's caused by a faulty oil drain that leaks oil into the down pipe. All in all, finding a used percision or turbonetics or what ever would probably be the same as getting a new master power, but theres probably going to be a higher fail rate on the master power turbo.
Mmmm....ok you guys have made tons of good points and yea ill keep shopping around and try to save a bit more money....thanks for all the imput and feel free to give more before i buy the turbo
You make a gamble with a cheap turbo, or any part that consist of the most critical aspects of your system. It might be even more expensive when something fails causing a chain effect of destruction (slag breaking away from a cheap manifold and being swallowed by your $$ turbo or wastegate).
yea true the manilfold is hard to find so i bought a turbo xs manifold
oh ok ill make sure of that then i also have a ebay manifold and it has a twin port instead of the single one like the xs manifold does which one is better...single or twin entry??
