TH400 in an SC300
Ok so im about to put my built engine and TH400 swap into an sc300. Looking for some vetrans at this.
A) what do i do about a trans mount?
B) how should i go about a drive shaft?
thanks for any info
thanks for any info
I have been searching for hours now, but more specifically about tunnel clearance. I have read, that it fits with the gm bell housing and adapter plate, I have read that it does not fit and you have to pound the tunnel, I have also read that if using a toyota bell housing no tunnel modification is necessary. can anyone chime in on what is true.
Thanks.
Thanks.
http://www.atfbilletparts.com/transm...-adapter-p-251
all you need is a bunch of adapters, torque converter adapter, bellhousing adapter, kick down electronic conversion, speed sensor electronic conversion, new shifter or some kind of conversion, trans mount adapter
just wondering , im doing a th400 swap, what issues will i get with the stock ecu as far as it not seeing the stock trans anymore ? any codes, or non startup problems
megamax
SC400 / 300 Classifieds
03-25-12 05:41 AM
