Ashtrays NA-T problem/help thread
#106
^+1 Well put that why i didn't even waste my time , the first thing i bought before i start my project was AEM 1100.
I didn't wanna go thru no hassle, i have seen local members on Piggyback going thru the same mess.
Sorry man.
Sorry man.
#108
All in all standalone is the most headache free/consistent route.
You could use the TT ecu to run your car, but since you are odb2 you will loose all your odb2 stuff and obviously won't pass emissions with that ecu, but then again you will have that same problem with the ems on odb2. something to think about.
and the FIC can control fuel and pull timing in boost. it doesn't modify the airflow signal like the safc, it actually changes the injector signal between the ecu and the injectors, and uses an o2 trick to tell the stock ecu that it delivered the right signal (even though it didnt even use that output). thats why it seems to work for all the is300's, but while its a more fancy trick than an safc, at the end of the day its still a workaround, but with improved results.
#109
#111
Edit: I think besides just ecu it would also require a different harness..correct me if Im wrong but maybe a few other things as well.
