HELP!! jzz30,jzx90 or jza70 harness
Hey guys, Im in need of some help, im trying to identify which 1JZ harness this is, it looks to be either a chaser(jzx90) or a soarer(jzz30) wiring harness but i would love to hear u guys opinions..
The pic isnt the best but its all i have at the moment...
![](http://i516.photobucket.com/albums/u322/lil_n8/wiringharness.jpg)
JZZ30![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
JZX90![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
JZA70
JZZ30
JZX90
JZA70
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
How many rows are the ECU plugs i know the Chaser and Soarer are 4 rows and the supra is 2 rows.
If you get the chaser on you will need to rewire the body plugs because it won't be PNP,
same with the Supra.
I don't don't how good you are with wiring but i would try to find a Soarer Harness.
what harness do u think it is??
But i thought it was the chaser(jzx90) wiring harness also, cuz if u look closely on the left side of the pic near the top it has the orange and white plugs and i dont think the supra(jza70) has those plugs on the harness at all?.?.? but im not completely sure
I kno its very hard to tell by the pic but thats all i have right now, if i can get in touch with the guy i will have him send specific pics of the ecu n body plugs
But i thought it was the chaser(jzx90) wiring harness also, cuz if u look closely on the left side of the pic near the top it has the orange and white plugs and i dont think the supra(jza70) has those plugs on the harness at all?.?.? but im not completely sure![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
The body plugs and ECU pins are different from the soarer and chaser setups. I think the chaser is short by two body plugs compared to the soarer, while the ECUs between the soarer and chaser are the same. If you can get a better pic of the body side of the harness i can compare mine more closely and confirm it.
But i did comfirm that its not a supra harness because the supra harness doesnt have the orange and white plug
Lokz
Performance & Maintenance
12-26-12 08:13 AM
