clutch replacement,tools and tips i need to know
i have 94 sc300 that im going to replace the clutch on with an OEM exedy clutch kit.Never done it before but just wanted to know any tips and any special tools needed.
removal of the trans is pretty straightforward, one thing im going to recommend is some long extensions to get to the bolts that are on top of the transmission. Also a set of 12-point sockets to remove the flywheel bolts (dont remember what size) and some of the bolts that hold the clutch in if im not mistaken. good luck
Also, get a friend who knows what he's doing. Always good to have a reference and an extra hand.
thanks for all the advice guys,helps alot.aslong as i can get the flywheel off in time before the machine shop closes ill be able to do it this weekend
well i tried to do my clutch today and epic fail.i got swivels,impact gun and i couldnt break the bolts off the drive shaft/diff for the life of me....very disappionted in myself
