DIY Tire Well Harness Relocation
Old 06-09-12 | 11:48 PM
  #121
hihopes's Avatar
hihopes
well i think drilling holes to pull it up farther up is still be a better idea than what i did.
once i get back from work tmrw im gonna tuck em through the engine bay. ill feel a lot better knowing theres no chance of my harness getting torn up.
Old 06-10-12 | 12:12 AM
  #122
OG Dada's Avatar
OG Dada
You cannot reroute the wire harness through there with nothing but high hopes! No pun intended. Do it right, do it right the first time.
Old 06-10-12 | 02:53 AM
  #123
baloyr's Avatar
baloyr
Default wires
does n e one know what the 3 green wires functions as? just wondering.. which is mostly green with two grey bars one inch apart?
Old 06-10-12 | 06:17 AM
  #124
chrisindub's Avatar
chrisindub
Default My way...............
You guys are funny
Attached Thumbnails DIY  Tire Well Harness Relocation-harness1.jpg   DIY  Tire Well Harness Relocation-harness.jpg
Old 06-10-12 | 06:22 AM
  #125
Cleanshots's Avatar
Cleanshots
^^^ did you just recently discover memes?
Old 06-10-12 | 04:06 PM
  #126
chrisindub's Avatar
chrisindub
what's a meme?
Old 06-10-12 | 04:09 PM
  #127
hihopes's Avatar
hihopes
hardy har har very original with the high hope joke
dont hate on the dirty engine bay or my blue tape! i ran out of black electrical tape and only had blue left
atleast now i feel better that i wont be touching those wires
Old 06-10-12 | 06:20 PM
  #128
pilotracer's Avatar
pilotracer
seems pretty simply and straight forward
definitely the next thing i do
Old 06-10-12 | 06:55 PM
  #129
MrCJ305's Avatar
MrCJ305
Originally Posted by hihopes
i tucked my harness up higher.. but i feel like its still not good enough. is this the spot where you guys tucked it? i wanted to tuck it higher but there was no slack..
front of fender:
top:
firewall side:
Same thing I did with mine until I do my swap. If you're stock this way is good to last, but if you're swapping the engine later on then I'd reroute it into the engine bay once the motor is out
Old 07-13-12 | 02:52 PM
  #130
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Putting detailed pics of the plugs here for others future reference incase something goes wrong.
(from my "SC in the attic")
Attached Thumbnails DIY  Tire Well Harness Relocation-img_6152.jpg   DIY  Tire Well Harness Relocation-img_6153.jpg   DIY  Tire Well Harness Relocation-img_6155.jpg   DIY  Tire Well Harness Relocation-img_6156.jpg
Old 07-13-12 | 07:31 PM
  #131
bryan767's Avatar
bryan767
Originally Posted by jintei
this is exacly what i did last night since i don't know how to unplug the other wire that goes inside the floor.
this way is so much easier and works as good, and no wire loom showing on the engine bay, which looks neater.
mines done the same way, except im LOW and im 80% positive im still rubbing.. i know the metal has been rubbed alot
Old 07-13-12 | 07:38 PM
  #132
bryan767's Avatar
bryan767
Old 07-13-12 | 10:25 PM
  #133
pieisgude's Avatar
pieisgude
at first i tried using zipties to tuck it up higher, but then i rubbed through those and i was back to square one. this method definitely is a must.
Old 07-14-12 | 12:30 PM
  #134
CalitriSC's Avatar
CalitriSC
^^^ exactly. I don't know why people try and take short cuts to save a whole 10 minutes. This is a very simple job. Why not do it right the first time? Zip ties will not last and it will still rub if your actually low.
Old 07-14-12 | 12:39 PM
  #135
chingpo05's Avatar
chingpo05
use adel clamps and tap screws.. im not a fan of more wires in the bay hence the reason why i tucked the rest . you just have to go higher and extend it 2 inches to get there.
