wire tuck engine bay??
Old 10-16-13, 12:48 PM
  #76
Halon
Halon's Avatar
I have a spool of 18awg, 16awg, and 12awg from Fleet Farm that I'm using for wires I need to extend. I also bought some screw clamp type splices that are good up to 2awg in case I need to extend any of the large power / ground wires. So far that has been all I've needed.
I also bought a bunch of loom from this place. I got a bunch of 1/4", 1/2", 3/4", and 1" since it's so cheap. Using it as needed.
http://www.parts-express.com/pe/show...number=080-525
Here's where I'm at so far on the passenger side:
Old 10-17-13, 10:20 AM
  #77
soarer13oy
soarer13oy's Avatar
Thanks for sharing!
Old 10-17-13, 10:58 AM
  #78
Ali SC3
Ali SC3's Avatar
looks good, there are so many wires there its a tough task.
would be nice to have a write up on it but no one has detailed one out yet.
Old 10-17-13, 01:18 PM
  #79
Halon
Halon's Avatar
Well I'm all for sharing. I don't think i'm going to spend the time to do a detailed write-up, but I will share as many pics as possible to hopefully help the next guy, or even get feedback from others who have done this on how I might have done it better. This is my first time ever doing any sort of wire tucking.
Old 10-18-13, 12:32 AM
  #80
soarer13oy
soarer13oy's Avatar
Will be doing mines in the winter. I would like to see more pics so i can get a general idea of where i might want to run the wires. My car rubs on the wheel wells on big bumps so i might have to raise it up a bit to be able to run the wires inside the wheel well.
Old 10-18-13, 04:59 AM
  #81
Halon
Halon's Avatar
Some more pics. I think I'm done with the passenger and driver side wires. One thing I may not have mentioned is I've removed my ABS, so the ABS fuse box and associated wiring is removed from the driver side. So the wire you see that I ran in that wheel well is just the brake reservoir sensor.
Passenger Side:
here you can see I extended the alternator cable about 8" or so and snaked it (and clamped it) around the bottom side there
the next few pics you can see I just used black zip ties to secure the loom. I also had to extend that wire that runs back into the engine bay near the firewall, must be for A/C or something.
How it looks in the engine bay now.
Driver Side:
Had to extend the brake reservoir wire (forgot how much) Probably could have extended it a little more, but I think it's probably fine.
Old 10-22-13, 12:25 PM
  #82
soarer13oy
soarer13oy's Avatar
Awesome job thanks for the pictures.
Old 05-24-22, 04:50 PM
  #83
Rcreegan
Rcreegan's Avatar
Originally Posted by TURBO819
Engine Bay Wire Tuck.
would love detailed information on this!
hoffy5
03-08-18 09:42 AM
Honda525
Build Threads
25
04-18-17 12:57 PM
grumpi300
SC- 1st Gen (1992-2000)
11-15-13 07:45 AM
SC300_704
12-28-06 08:31 PM
chitwnsazn
07-07-04 04:24 PM
Quick Reply: wire tuck engine bay??
