1JZ-GTE water pump
1JZ-GTE water pump
Anyone know how I can replace my water pump on my 1J? Ive read I could use a 2J water pump from a supra but am not sure. Mine is whining like a b*tch and makes the car sound horrible. Any guidance on this subject goes very much appreciated.
Basically, if your fan is directly bolted to your water pump (assuming you did not convert to electric fans) it is a mechanical pump. On the hydro pump, the fan is not directly attached, and run off a separate dohicky. If it's a hydro pump, you should have an extra reservoir labled fan fluid.
Mechanical pump
Hydro pump (i know its a 2j, but same idea)
Mechanical pump
Go ahead and buy all the major 90k service stuff if you're getting the pump done. You can get a new GTE water pump for ~$160 and timing belt is only like $30.
kool. yeah i want to do the timing belt too but my dad said they have idler pulleys on the motor so to get a timing belt kit. my next question is will one from a turbo supra work as well?
i greatly appreciate all the help guys
