need help! idle drops.
hey guys so i was driving lastnight, and all of a sudden my needle drops. it didnt die out but was about to. when i step on the gas the needle will go up but wont really get anywhere. then when i let go, the needle goes down to where itll almost die. has any of you guys experienced this? and were you guys able to fix it? im getting some new wheels, it would suck if this is something serious.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
its your idle air control valve. a stepper motor that bypasses air past the throttle body to give your car enough air with the throttle body closed to run. located on the throttle body held in by 2 screws. take it out and spray some carb cleaner on it. i bet its getting clogged with sludge
Technically, NO. It is accessable on the car....but as I said above, if you remove the TB first and then remove the screws with the TB sitting on a bench where you can get an optimal attack on them, your less likely to strip them. It's your call.
and for the screws. it's not that tight. you just need the right screw driver and wd40.
make sure you replace the bearings or spray wd40 on the old ones. it makes one hell of a big difference. i cleaned my iacv without replacing the bearings or spraying the bearings. i did this for a couple weeks-a month and the iacv would run fine one day then the next it would get stuck and my car wouldn't start unless i step on the gas. so i decided to spray wd40 on the bearings and it never got stuck and cars been running fine for 2 weeks str8 now. me is happy!
