Na-t fitment issue
Ali thanks i got some broken connectors replaced, and installed the engine harness all the sensor are connected.
I ran the IC piping damn that's alot of pipe lol, after the tune i am getting the FFIM unless i can route it a different way.
Adam I was working on the car and left the phone in the house, i am almost there.
I decided to use the TT pedals i got the pedals, nuts, bolts, springs, retainers, and bushings so those will be install tonight.'
I need to install these parts, alternator, starter,slave and master cylinder,radiator, electric fans,boost and Afr gauge,ems etc alot of little stuff here and there.
Ali the ground wire that comes off the the VVTi ignitor is it a chassis ground or ECU ground that's the only wire i have left and that was the wire you called me about last week end let me know so i can fire it up.
DINH300
Performance & Maintenance
01-10-09 07:24 PM
EvolvedGS3
Performance
11-01-07 09:13 PM
