High Idle (1900 RPM) on cold start and RPM drops then surges
92 SC3 w/ IS3 intake mani. if the accelerator is not depressed the RPMs surge then drop and I want to know what this could be? IAC,TPS,or MAF or something else. Thanks.
Also the high RPM cold start causes some rattling to occur in the engine for about 1-2 seconds then it goes away is that a problem that needs immediate attention?
Do the revs drop when the engine is warm? SC's do this when they're cold - it's just the engine warming itself up. As for the rattling, I wouldn't worry as long as it goes away quickly. My dad always used to say, "If it ain't broke, don't fix it." I'd just drive it and if you notice anything exceptionally weird then maybe have a mechanic take a look. Otherwise, you should be fine.
If I am braking the RPMs drop and surge. If I am at a red light the RPMs drop and surge, sometimes so low the car almost dies then it catches and surges again. This problem just started about a month ago. As long as it is getting some gas it holds RPMs just fine it is only when the gas pedal is not depressed that it does this.
As Far as the surging it might be your Battery ground cable is erroded. Buy a Ever start Neg Battery cable 15" 4 Gauge from Walmart for 7 to 8 Bucks and connect it to bottom ground bolt. Follow the cable down and you will see it. Leave the excisting cable hang. I think the surge is happening everytime you hit the brakes. This is a Inexpence fix and it got rid of all my electrical gremlins that I was having. Let me know if it works
I kinda get the same thing and don't know what it is. It only happens on cold starts. The engine will rumble on and off at around 1800 rpms, just up and down, some shaking then smoothing out. This goes back and fourth. Once the engine is warm, this goes completely away
Have no idea what it is
could be a lot of problems. i suggest you buy a ohm meter and test your idle air control valve and maf sensor. if they both work fine, try cleaning the idle air control valve and replace the bearings. if still have the same problem, buy a new used ecu.
make sure ground connections are good, battery connections are good.... Like said, check IACV, check maf, most importantly check for vacuum leaks.
Once you've done that, seafoam the car through the pcv or brake booster and reset the ecu. This should reduce you surging a little bit.
grindin8o8
Performance & Maintenance
03-08-10 06:25 PM
Lexucan
15
09-15-07 02:14 PM
