Traction control off
Hey guys,
I tried searching but I couldnt find anything...
I have a 95 SC400 and I cant seem to turn the traction control ON. Has this ever happend to anyone? How can I turn it back on?
what lights are you seeing on your dashboard? any check engine lights or the trac light lit up fully. if traction control has never worked open the hood and on the drivers side there is a small fusebox with 4 relays. double check the trac control relays are still in there (4 total). sometimes people pull these out to disable the trac.
I think the problem is with the TCS itself. If someone had pulled a relay to disable the TCS you would have the "Battery" Light lit on the dash. I would replace all relays and fuses for the TCS. And see what you get. It is alot cheaper to do that than buy a new TCS components.
If your little "trac" light is on, then you need to pull the codes for the trac system.
blkis_250
05-23-20 01:53 AM
TroyzLegit
08-18-18 03:07 PM
