DIY: GM th350 swap and Hurst Pistol-Grip Shifter Install
Old 04-20-10, 08:35 PM
1siksc
1siksc's Avatar
Thanks Nelle and no worries about being a light weight here, I am kinda looking forward to that part. My break of resuming this is gonna be even longer then I was hoping :/ The Torque Converter is gonna be like 700 and I emptied my bank account out the last 2 weeks, uhh! >_<
Old 04-21-10, 03:29 PM
hyjaxx
hyjaxx's Avatar
Oh yeah- one other thing...I went with a cheap brand flexible dipstick and had to scrap it and buy a Lokar. Save yourself the trouble and go Lokar the first time. What converter did you decide to go with?
Old 04-21-10, 07:15 PM
1siksc
1siksc's Avatar
how come you had to scrap the dip stick, i did the same. Just a dip stick? Still deciding... anywhere from 5300 ro 6000 stall.
Old 04-21-10, 08:23 PM
hyjaxx
hyjaxx's Avatar
Woohoo way to go with a damn nasty stall! You certainly aren't here to f spiders!I have a Precision Industries and it's been good to me- I was happy with my stall- it came in under the 4000 I had it flashed to by like 200rpm. The damn dipstick...the way it sat at the base was absolute crap and the actual flexy-part inside used to hang up going in. Very freaking annoying.
Old 04-21-10, 08:53 PM
1siksc
1siksc's Avatar
hmm, I'll have to send you a picture of the one I got, mine actually seems to be a direct replica of the lokar.
Old 04-23-10, 05:31 PM
1siksc
1siksc's Avatar
Resuming this beast! Picked up a DaveH 5500 Stall Torque Converter.
Old 05-09-10, 08:27 PM
1siksc
1siksc's Avatar
Got the Torque Converter 2 days ago and finally had some time to work on the sc.
Before
After...
progress that was made, Cut the tabs off each side and leveled the top down hopefully to make it easier to fit into the engine bay, I also picked up all the hardware needs for the adapters but the hardware store failed to carry a sufficent amount of the size needed. So until Tomorrow or Tuesday I am a little paused.
Old 05-10-10, 07:55 PM
1siksc
1siksc's Avatar
Red Locktite all bolts that are on the torque converter adapter and 61 ft lbs torque bolts are m12 x 1.25 and the smaller are m10x1.25 i believe Blue locktite all others.
I was unsure of the torque specs on the torque converter to adapter bolts so I just tightened them by hand and used Red Locktite.
All together
Hurst Shifter Adapters mounted
In the lower left you can see where there will be some denting of the engine bay to make it fit right.
Old 05-11-10, 07:53 PM
1siksc
1siksc's Avatar
seems like you mildly have to pound the well. more pics tomorrow, seems to be a tight fit for the tunnel , have yet to check it out.
Old 05-16-10, 09:32 PM
1siksc
1siksc's Avatar
trans mount adapter in action. Had to remove Hurst stuff on trans more tomorrow.
Old 08-26-10, 11:34 AM
1siksc
1siksc's Avatar
this sunday i will get more pics up, sorry last sunday I couldn't find my camera. This is from 2 weeks ago sunday, measuring for driveshaft.
I just bought this as well, differential adapter from driftmotion.com
Old 08-26-10, 11:45 AM
1siksc
1siksc's Avatar
from 2 weeks ago again, cut a hole in the car for the hurst shifter adapter. Gonna be covering up with sheet metal.
Old 09-02-10, 05:22 AM
1siksc
1siksc's Avatar
Drift Motion driveshaft adapter along with a new trans filter and gasket
Old 09-05-10, 08:42 PM
1siksc
1siksc's Avatar
Trans Lines made and ran all with 2 75 degree 6an off of trans then ss braided 6an to the Greddy Grex cooler 2 90 degree 6an.
Old 09-05-10, 08:45 PM
Soarer.jzz
Soarer.jzz's Avatar
wats up chris? I'll have to post a pic up somewhere. you ready to take yours to the track yet??
Quick Reply: DIY: GM th350 swap and Hurst Pistol-Grip Shifter Install
