Na-t she woke up this morning
#181
SC is running but i need to work out some of the bugs, get my tach and the rest of the accessories to work .
I still need a new p/s pulley, new fan, new fan shroud and interior upper trims front and rear in black.
coming together slowly but surely i had set my deadline for tomorrow wednesday but the car is 90% complete so i will finish it next month, car won't be driven till everything is 99% done.
Still need to replace the control arm , tie rods inner and outter new rack and rack bushing i will replace those after i get it on the road because i can do the alignment at my Job after the i replace all those suspension parts the wheel will be a little off..
i know , i know you guys want some pics they are coming this week end.
Ali i tried swapping the cruise switch but it won't bolt right up, because i am using a Matrix steering wheel and airbag it's little diffferent than the SC. You have an RX steering wheel so it bolts right up to the SC and is almost PNP.
Do you know how to convert a Dual Stage air bag to a Single stage airbag? i need to convert mine i know it has been done here i justy don't remember who had done it before maybe "Kipod".
#183
Thanks bro.
Well some of the bugs worked out, sounds good but i need to fix my temp gauge it goes straight to hot when you turn the key on.
Installing a 97 Sc300 engine and harness is 93 SC400 sucks will never do it again....wiring color on the 97 Harness is completely different.
Should be all done this weekend since the UMD Meet got cancelled so i will have enough time to work on it tomorrow and monday since am off on mondays.
I need to replace the fuel pump with the stock one car is running very rich.
#184
I Finally had time to finish the SC this weekend Thanks to Balconnelly and Red95sc for the help these two guys helped me the whole day.
Well i just need to bleed the brake, and i am back in business...
Brakes should be done tomorrow then i will tow it to my job for some suspension and exhaust work..
very happy with the outcome balconnelly will take some pics and post them up..
#191
why do you wanna see the pics? you've never seen an SC with TT wheels?
My engine bay doesn't look as good as yours!!
You know i don't have the time to take pics while am working but AL will post some pics soon.
