Na-t she woke up this morning
Thanks man, I hope to get that resolve by monday.
The TT brake pedal has a different shape to it it fits but will never work unless you bent the arm backward.
And the clucth pedal feels like a two step clucth, when you press it it soft and goes about an inch or so and stop , then when you press it hard it will go another half inch or so.
and when i look at the rod from the clutch master that come thru the pedal bracket to the pedal it flexes down like it about to break of or something i don't.
Will post pics and Vid
My car is 95 SC3 here is the mods list
2JZGE Botton end
TT headgasket/TT cams/TT cams sensor/TT oil pump/TT crank sensor/TT crank gear wheel/2JZGE VVTi Cylinder Head/VVTi ignitor/VVTi coils/Supertech valve seals/VVTi upper intake manifold/AEM EMS 30-1100 with 5bar Map sensor/ GM IAT sensor/Tail 44mm/HKS SSQV/BILLET 6765S .81AR/R154 rebuilt with MC parts/ ACT xtreme stage 4 632 Lbs TQ/ TT brake/clutch pedals/TT slave cylinder/GS400 3.26 diff/ AEM Wideband/VVTi Water pump/Gates Timing Belt/1000cc low impedance/ Honda civic reistor packs can't remember the rest of the stuff.
Aiming for 615Rwhp on Pump gas around 19PSI my CR is 9.2.1 so i know it could be done!
Thanks for all the support.
2JZGE Botton end
What TT cams do you have in?
I have a set of USDM in the head right now and will be installing a set 272hks.
I wanna see how the perform first and i wanna make sure the shop did a good job machining the cams to fit the VVTi head so if the stock TT cams perform well i will let them machine the HKSs also.
I know 615 is alot but you got to set your goal high ,so anything over 500 i will be really happy and thankful.
I really didn't wanna do cams, i just wanted see the max out of this setup without blowing or breaking anything then upgrade what needs to be.
My tuner said he could make it happen so let me see i wanna put him to the text lol.
Hey Wicked How is is the Black beast coming along ?
it was fun tho... I LIKE THE PICS, maaan nice
