Na-t she woke up this morning
After 6 months being dead she finally woke up at 2:25AM this morning
She started right up after 6 months from a major surgery,i don't know what to say
After 3 different setups finally got what wanted.
I will post the pics, i have alot of pics on my phone but i don't have internet on the phone and i tried to upload them to the computer but it wouldn't sync.
I am going to take alot of pics on the digital camera and upload them.
Ali the 3 wires that goes to the AEM which are Coil1/Coil2 and Coil3 i have to redo them because where you solder the pin to the wire it was kind of fat so it wouldn't slide in the ECU connector, so i had to cut them off and redid the 3 wires which was easy and let me know when you are ready to do yours bart has some of the ecu pins and wires left that you can use.
One shot she fired right up so happy didn't even sleep last night hahaha.
Thanks Ali .
Thanks Ali .
Thanks Ali .
Thanks Ali .
See, you are good at wiring, you just didn't know yet.. lol.
I will let you enjoy your car for a little while before we tackle mine.
I can't believe it fired up on the first try with those injectors and everything.
sounds like success to me.
I've got a new project for the stock ge intake manifold. I think you will like it.
Lol no i don't like wiring if i don't have too seriously and you know that man.
We can do yours when decide to replace the HG.
Yes on the first try i was shocked lol Bro ni joke.
Come get the lower runner if you need help with the project let me know.
Will post pics and Vid
My car is 95 SC3 here is the mods list
2JZGE Botton end
TT headgasket/TT cams/TT cams sensor/TT oil pump/TT crank sensor/TT crank gear wheel/2JZGE VVTi Cylinder Head/VVTi ignitor/VVTi coils/Supertech valve seals/VVTi upper intake manifold/AEM EMS 30-1100 with 5bar Map sensor/ GM IAT sensor/Tail 44mm/HKS SSQV/BILLET 6765S .81AR/R154 rebuilt with MC parts/ ACT xtreme stage 4 632 Lbs TQ/ TT brake/clutch pedals/TT slave cylinder/GS400 3.26 diff/ AEM Wideband/VVTi Water pump/Gates Timing Belt/1000cc low impedance/ Honda civic reistor packs can't remember the rest of the stuff.
Aiming for 615Rwhp on Pump gas around 19PSI my CR is 9.2.1 so i know it could be done!
Thanks for all the support.
2JZGE Botton end
Got some bad news, last night i bled the clutch system and the pedal doesn't feel right so i will pulling the TT brake and clutch pedals annd just get the lexus one.
The brake pedal doesn't even work.
