1jz "2 oil pans" question
Im i the middle of changing all the gaskets,belts etc.. on the 1jz motor before I install it. I'm about to take off the oil pan. Do you guys think I'll be ok just changing that lower oil pan gasket or do I have to take like the whole bottom of the motor off and put a new gasket on that to?
I've never see a motor like that. I'm used to just an oil pan. It looks like the whole part above the pan comes off also. I really rather not mess with that.
let me know what you guys think. Thanks And yes I did a few searches and did not find what i was looking for.
I would remove the *lower pan, check the pick up tube screen for metal or debris before the install. If all ok, great. Use rigid diff cover silicone to reinstall and you will be golden. Dont bother with the upper pan if it is not leaking.
Frankdms- thats what I was thinking. Just do the lower. But I never put the motor in yet. So I dont know if the upper is leaking or not. It looks pretty clean around the upper area so I would think its not.
Cavette-champion Toyota ask for Jeff. 1jz gasket kit.
if the motor is out, why not go ahead and remove the upper oil pan, clean and reseal it? doesnt take that long to do and you will be happier in the long run and if that upper pan does end up leaking if you didnt change the gasket then you would either have to drop the subframe and uninstall or take the motor out again to replace. save yourself some time and trouble and do it now. that sealant is only $10.
I just did not want to get into it. I dont even see the complete seam of the upper pan. It looks like its the whole bottom half of the motor. It looks like the section were the tranny bolts to the block comes down also. I'm just not confident unbolting all those bolts and not even seeing a defined seam where the upper pan should drop.
Use a good sealant and pay attention to where you clean the old sealant off. apply new sealant on the same areas. RTV Gray, Sealant or from a Toyota dealer.. Tighten all the upper pan bolts and then go over the bolts again making sure you tighten them all.
