OBDII swap possible?
I have been digging for info on this swap and have found very little.
Someone said that to swap an OBDII car with a 2jzgte and retain the OBDII port function is "tricky". It seems like running a USDM OBDII supra ecu through a hybrid harness would make this swap easily doable.
What am I missing here? I imagine finding said ECU would be tough, but other than that and the obvious harness tweaking, what else would one need to convert?
I always suspected it was doable with an US odb2 supra TT ecu.
If your car is originally odb2, you could use the same philosophy as using a odb1TT ecu in an odb1 SC. just wire up the extra ignition wires and plug in the supra ecu. there may be more with the odb2 stuff but i doubt it.
heres my thread with the diagrams for odb1.
https://www.clublexus.com/forums/sc-...-odb1-sc3.html
JJG2005
Performance & Maintenance
06-26-05 10:59 PM
