Tt ffim
Old 05-18-10, 01:48 PM
  #46
99SC42
99SC42's Avatar
Wow it looks good, all you need now is the VVTi GTE Valve Covers and your are set that the only thing missing.
Old 05-18-10, 04:13 PM
  #47
SC300_704
SC300_704's Avatar
nice! so did you cut the flanges and welded it together?
Old 05-18-10, 04:53 PM
  #48
SC51
SC51's Avatar
turbodremz that looks great..have you had a chance to start it up yet?
Ya Its unfortunately my DD so its gotta be driveable
joe diego That ***** looks tuff. This is something I would like to do in the future.
Thanks it was a bit of work!
Ali SC3 looks nice, did you get it welded or use a gasket, and if its the gasket what type of material?
Used stock GE gasket and some gasket maker.
quickGS300 Wow it looks good, all you need now is the VVTi GTE Valve Covers and your are set that the only thing missing.
Thanks ya thats my next thing. Do you know if it bolts rite up?
SC300_704 nice! so did you cut the flanges and welded it together?
No I want to in the future tho. as well as get a TT TB
Old 10-19-10, 10:43 PM
  #49
EDTUN3R
EDTUN3R's Avatar
I would Of Taken The easier Route And Swapped In A GTE head
Old 10-19-10, 10:57 PM
  #50
turbodremz
turbodremz's Avatar
how is that the easier route?? find the right GTE manifold and it bolts straight to the GE lower runners...not to mention, its much cheaper going with the GTE manifold
Old 10-21-10, 08:18 PM
  #51
madmax98
madmax98's Avatar
Tell me you don't have the VVTi bottom in their....
Old 10-26-10, 06:29 PM
  #52
SpiderN9NE
SpiderN9NE's Avatar
Post Ok
Ok he did have the vvt-i bottom end but no where does he say that he was trying to set a world record. just a na-t setup and wanted a ffim.
he now has a gte swap.
Old 10-26-10, 07:57 PM
  #53
TroySC300
TroySC300's Avatar
Originally Posted by Pipe
car comes factory with ATF in the PS don't know If adding regular stuff ruined anything?
I don't think it would be a problem either way,It could be the unit itself.
Using PS fluid in our system is notorious for causing leaks. Switch to ATF asap imo.
TT FFIM looks great!
Old 11-06-10, 07:46 PM
  #54
2muchboost
2muchboost's Avatar
SC51 could you get us some more pictures possibly from different angles? Thats probably the route I am going, I have access to a nice TIG welder but just to keep it simple for now it would be much easier for me to just do what you did. Thanx for the information, i am sure all of us learned a thing or two.
Old 11-07-10, 07:04 AM
  #55
SC51
SC51's Avatar
Pretty much those pics will have to do because the setup is long gone, all my new pics are GTE. You can do what I did and run a leak down test to ensure no leaks or to ensure it, weld it!
djkevin510
19
02-24-14 12:40 AM
broda805
13
02-13-14 11:30 PM
That-Guy
01-23-09 11:05 PM
bighitbike
Suspension and Brakes
06-25-07 04:27 PM
SinisterSC
10-20-04 09:09 PM
Quick Reply: Tt ffim
