Tilt steering repair
Old 05-16-08, 07:10 PM
  #136
dantama
dantama's Avatar
Thanks for taking the time to post pics. Good info
Old 05-28-08, 05:02 PM
  #137
cheesey1x
cheesey1x's Avatar
thank for the write up i just fixed da wifes
Old 06-01-08, 01:33 PM
  #138
ghost9er
ghost9er's Avatar
Default my 92 sc300
thanks for the info i just brought mune for 1200 today and that was one of the problems it had easu fix thanks again now to get replacement seets and a body kit im gonna make my boy shine
Old 07-13-08, 01:24 PM
  #139
suprandsc
suprandsc's Avatar
Okay, I have a similar problem with my newly purchased SC, but symptoms are a little different.
My auto steering(steering wheels moving when ignition is on and off) stopped working, but manually, the steering wheels tilts,goes up and down with no issues. I assume this is maybe a loose wiring of that auto steering buttom or something? How and where is the wiring located? any tips or suggestions?
Thanks,
JP
Old 08-10-08, 12:58 PM
  #140
aggieguy
aggieguy's Avatar
Perfect. The dealer quoted me $800 to repair this. I did it with three 7/16 neoprene washer from Home Depot (on the nails and screws aisle). Total cost--62 cents, time about 15 minutes. THANK YOU for posting this--it will save lots of people lots of $$$$$$$$.
Old 08-22-08, 05:33 PM
  #141
bbhua00
bbhua00's Avatar
alright guys...heres the scoop. i did what was instructed because of my tilt reason too. once everything was done, i tried the up and down motion and it worked but the up motion doesnt work...so what now guys
i have it all the way down and its pissing me off LOL
Old 08-22-08, 06:25 PM
  #142
TroySC300
TroySC300's Avatar
Originally Posted by c_irie
this is the wheel which I removed using two paper clips with the tips bent.
I tried removing this wheel recently but failed... Any tips on removing the blue gear?
Old 08-22-08, 06:35 PM
  #143
aka paco
aka paco's Avatar
thanks to original post, i love seeing how to's on stuff we will all have to deal with sooner or later!! lol
Old 08-26-08, 09:37 AM
  #144
suislide
suislide's Avatar
thanks. bump!
Old 09-06-08, 04:41 PM
  #145
acenase
acenase's Avatar
Does anyone know the Size, Width/Height of this Washer because I went to go buy this today and there are all different sizes and I didn't know which one to get! Is the Washer supposed to be metal?
Old 09-16-08, 08:10 PM
  #146
N1T3MARE
N1T3MARE's Avatar
I just fixed mine yesterday and I used a garden hose washer on the backside of the blue gear and put everything back and it works perfect. Thanks c_irie for his awesome write-up and pics.
Dee E.
Old 10-20-08, 09:11 PM
  #147
acenase
acenase's Avatar
Somebody Please Help..
I finally got those 3 screws loose and I can see the Wheel now.
The only problem is, I CAN'T remove the wheel! That screw is in the way (do I need to remove the screw? If so what size is it ? I tried evrything and nothing fit) and this little metal piece is in the way!
I tried pulling it with 2 paper clips but it is stuck in there. Do I need to remove the screw in front of it?
Old 10-20-08, 11:20 PM
  #148
Cleanshots
Cleanshots's Avatar
yea dude, un screw it......
when i did this repair i had to put a washer behind it not in the front... guess it depends which way its messed up
Old 10-21-08, 10:41 AM
  #149
acenase
acenase's Avatar
What size wrench do I need to unscrew it? I tried everything but couldn't get it to fit. The wheel is very loose, I can push it back and forth.
I think my problem is this little metal thing is in the way which is what is making it a lot harder.
Once I get this wheel off, I can put my washer behind it and hopefully everything will work again.
Old 10-21-08, 11:14 AM
  #150
Peter_95
Peter_95's Avatar
sweet.... now i know how to repair if mine goes bad.
Quick Reply: Tilt steering repair
