Tilt steering repair
Old 06-18-11, 08:49 AM
  #241
brightlake
brightlake's Avatar
This is a great post, and they do sell those washer in Lowes. Cheap.
Old 06-18-11, 08:56 AM
  #242
brightlake
brightlake's Avatar
Originally Posted by sc4doubleO
Mine needs replacement too its all chewed up.
You should be able to do it if you remove the wheel and turn it around. My looked bad too when I removed it (with obvious amounts of plastic falling off). But I turned it and used the other side. It works well now. Good luck.
Old 06-18-11, 09:06 AM
  #243
socal72
socal72's Avatar
Yeah, but if you dont space it properly with the washers your goin to run into the same problem down the road bro. I would take it back apart and install the spacers if I were you. Just my 2penny's worth..
Old 06-22-11, 01:11 AM
  #244
bleedspeed
bleedspeed's Avatar
it would be good if we could track down a generic tilt motor that could be made to work for a lot cheaper. its just a plain motor for the up down tilt. only thing special about the motor is that the mounting bracket is welded on. gotta be a way around it!
Old 06-22-11, 01:19 AM
  #245
bleedspeed
bleedspeed's Avatar
all we need is the specs from the original tilt steering motor right?
check this site out.
http://www.powerelectric.com/product...ar-motors.html
Old 06-22-11, 03:18 AM
  #246
Confusion
Confusion's Avatar
what size washers are those used in the DIY?
Old 06-22-11, 05:32 PM
  #247
socal72
socal72's Avatar
C_irie's DIY says to use 3 0.27's two in back on in front.
https://www.clublexus.com/forums/sc-...ng-repair.html
Old 07-08-11, 04:04 AM
  #248
johnnyr888
johnnyr888's Avatar
Thank you, thank you, thank you. Brilliant well-illustrated step by step instruction, easy 20-minute fix, saved me hundreds! I could not be happier....And yes, 2 garden hose gaskets do work!
Old 07-08-11, 07:00 AM
  #249
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I have used this method on so many SC's that this has seem the problem.. This why it needs to stickied...
Old 08-16-11, 09:04 PM
  #250
jhustle
jhustle's Avatar
thank you sir..i have been driving a school bus for the last 2 weeks
Old 08-16-11, 09:35 PM
  #251
Alex2JZSex
Alex2JZSex's Avatar
Thanks, helped out!
Old 08-17-11, 07:33 AM
  #252
cmh
cmh's Avatar
damn good thing this thing got bumped my steering wheel tilt just messed up last night. gunna fix it this weekend.
question... someone on this thread said he manually tilted his steering wheel... i thought if that thing was messed up u couldnt tilt it anymore... is there a way to manually tilt.????
Old 09-14-11, 02:22 PM
  #253
gcollins
gcollins's Avatar
Default My first Post---auto tilt steering
Great Forum and impressive video for the fix. This is my first post after owning SC's for 20 years---and this is my first required repair. What a great car and would be owning the original if it wasn't totaled by an idiot.
Changed battery, turned key on and tilt steering--locked in up position.
I will take apart tonight and do the 3 washer fix.
My question is I have changed batteries in a sc300 -3 times and in my current 1999 SC400-two times and this was the first time I have incurred the problem.
I also noticed one post in this thread about the battery issue and I believe he simply disconnected the battery and VOILA--fixed. I have not done this as a neighbor changed his battery--had the same problem and had to have his engine retimed in addition. WTF--is there a procedure for changing a Lexus battery?
Old 09-14-11, 03:19 PM
  #254
cmh
cmh's Avatar
i can say with almost all certainty that the battery has nothing to do with the tilt steering. i went to turn my car on from one day to another and it didnt work anymore. its something that just happens. it is sooooo easy to fix it to. i used the little circle pads u put under furniture so it doesnt scratch the wood and it worked great.
battery: no there is no soecial way to change it. just make sure u dont cross the cables. in the 400(not sure if the 300 too) it is very easy to get the two terminals mixed up. other then that very straight forward. take it out and put the new one in. gl
Old 09-14-11, 07:48 PM
  #255
gcollins
gcollins's Avatar
Smile steering
CMH-- thanks. Did the insert washer solution and Voila--all is good. c-irir== what a great video.
Turned off the auto up down button and will do it manually.
Since I am an engineer-- I don't believe in coincidences-- the battery matters somehow?
Quick Reply: Tilt steering repair
