HELP! JZZ30 Soarer differential side bearings
I have a 1994 Toyota Soarer (JZZ30) with a factory 5-spd / open dif (A02A)
I am installing a KAAZ 2-way LSD and need to replace one of my side bearings. They are the 2 identical pressed steel roller bearings that sit on either side of the dif.
Problem is that I cannot find the proper replacement bearing to save my life. Any parts I have tried to reference (ie, for sc300 or supra) have been incorrect. The part listed to the sc300 for example is a TINY bearing and doesn't fit.
I have the correct unit. My Kaaz LSD is model DAT3020 which is for JZA80 Supra/Soarer/SC300/SC400 etc.
The bearings I pulled off of my factory differential fit perfect onto the Kaaz but I cannot find a replacement.
Like I said .. the one that gets pulled up that I checked for at Toyota and even PartSource is incorrect and would never fit.
they use the same bearings. Kaaz wouldn't sell the DAT3020 under both models if the bearings were different in all 3 dimensions ..
my oem bearings fit just fine on the kaaz unit, as they should. the problem is that I'm getting referenced the wrong part number for a replacement... the new bearing under the matching part number does not fit.. on either the stock diff or my new kaaz unit
Vanu
Performance & Maintenance
03-16-19 09:18 AM
