official 1jz vvti parts thread
#106
Really not trying to be a d-bag, but I believe you're spreading mis information dex.
First, you replied to my post about the non vvti injectors saying they work with the older rail on the vvti, wrong. The mounting tabs and fuel ports are completely different. You MUST use the non vvti lower intake AND non vvti fuel rail together.
Second, why do you say you need a five speed ecu? That's a crock.
I'm not hating about you having more money, faster car, etc, but if that excuse makes you feel better, then I'll give you a cookie. I'm just saying that this thread is, or started
Off, geared towards the diy-er, and we should keep it that way. Stop spreading misinformation, or if you post, make sure it's clear or concise. <3
#109
Mr griffin if you still need that crap I prob have it
http://www.youtube.com/watch?v=OVTMl...e_gdata_player
http://www.youtube.com/watch?v=oL7FE...e_gdata_player
Setup is:
1jzgte vvti
Stock injectors
Walbro 255
Nozzs (?) manifold off eBay
44 mm tial mvs
Holset hy35
4" down pipe
14 psi
Bkr7e @ .024
~3200lbs
untuned, no piggybacks
Car hits fuel cut in 3rd through 5th bad at wot, but feels amazing. I have ****ty piping, turbo side has a huge kink and I still get 14psi by around 3600. Jumps from like 8-14psi in about 200rpm's. Can go 2/3 throttle all the way up, beat a couple 330ish whp mazdaspeed 3's the other night feathering just under cut.
This thing with the Holset comes on line nearly as quick as the non vvti 1j with twins that it replaced.
Setup is:
1jzgte vvti
Stock injectors
Walbro 255
44 mm tial mvs
Holset hy35
4" down pipe
14 psi
Bkr7e @ .024
~3200lbs
#110
Would also like to add that the manifold was a huge pile of crap. I had to wallow out the holes on the flange to the head to get it to fit right, it also needs to be decked and had to wallow out the holes on the turbo and t3 gasket so it would fit the crappy t3 flange. I also completely changed the dump tube as it was facing forward. And a bunch of clean-up grinding. Maybe they revised it since then, but it was a hassle.
#111
#115
so, i figured out the AC after a little testing last night.
the Blue/Red wire on plug A, it pulls to ground with the A/C switch to ON.
ALSO, when the Chaser ecu sees a ground at the AC pin (signal input so it knows to raise the idle) it puts out +12v to the ACMG pin (out to the AC relay)
THIS IS BACKWARDS FROM THE LEXUS ECU (the Lexus ecu grounds pin ACMG, which grounds the AC relay).
so i just ran the ac switch wire from the climate control down to the ECU (to ground that pin and raise the idle) and tee'd the wire up to also ground the AC relay. it's perfect.
*contributing more to the people who couldn't find all the hidden Chaser ecu information*![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#116
Cartmill, i just decided to hook up the ac, i understand how the coponents works but i tried to find the wire that pulls to ground when you push the AC switch to ON you said the blue and red wire on the plug A which i dont know which plug you are talking about. I have tried all B-R wires that i saw that connects to the AC controller and the plug that connects the ac wires to the engine harness under the blower... nothing pulls to ground when i push the switch... i must not see the plug you are talking about
plug A is the smallest of the 3 plugs that plug into the back of the climate control unit. 11 pins.
also, are you checking B/R wires, or L/R wires?
B/R (what you posted above) is black with a red stripe. L/R is blue. just want to make sure
what year is your car? i was doing all of this to my 92 sc400.
#117
Thanks Cartmill, i was checking the L-R wire as it was shown on my diagram but it was really dark outside so maybe i was not seing correctly, i had the car running and spliced the wire and check continuity to ground on the chassis whhen ac boutton on and of and nothing either way but i will try with the L-R wire on the smallest plug again.
thanks
thanks
#118
also, (IIRC) be aware that that pin is very low voltage when the AC button is OFF, and goes to ground with the AC button ON, so you may need to set your voltage decimals over 1 or 2 places on your multimeter ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
it should show up as voltage with the botton off, ground with the button on.
again, it's been a year since i've done this, so i could be totally wrong
#119
i havent work on it yet but i was checking continuity to ground not voltage, usually there would be almost no resistance to ground (chassis) if i turn the ac on but there was no connection between ground and this wire. maybe it is so small or maybe it is a different ground then the chassis which i would not really get but i will try tomorrow and i will give you my results.
#120
i havent work on it yet but i was checking continuity to ground not voltage, usually there would be almost no resistance to ground (chassis) if i turn the ac on but there was no connection between ground and this wire. maybe it is so small or maybe it is a different ground then the chassis which i would not really get but i will try tomorrow and i will give you my results.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
ok that continuity test matches what i was saying about the voltage at that pin.
so if you hit the AC button, that pin goes to GROUND. that matches your test.
now check the voltage at that pin with the AC button OFF, and the pin should have .1v or some small amount of voltage (.1v is just a guess).
