Looking to do a r154 or w58 manual swap? look in here, dont make a thread.
Old 04-30-12, 01:20 PM
  #121
99SC42
99SC42's Avatar
MK4 front is too short..
Old 04-30-12, 03:17 PM
  #122
VileFCboy
VileFCboy's Avatar
Originally Posted by Quicksc4
Driveshaft has to be from an SC300 not MK4 , so if you have one from an SC300 you are good to go sir.
From my understanding from other various thread as well as the first post that Cleanshot posted here, you can use the front half of the driveshaft from an MKIII as well right?
If I do use the MKIII driveshaft for the R154 swap, I would have to just swap the center bearing from the SC300's auto driveshaft am I correct? Clarifications please.
Old 04-30-12, 03:34 PM
  #123
99SC42
99SC42's Avatar
Yes mk3 front half for R154 in the SCXXX, use the SC300 carrier bearing ..and sc300 rear half.
I have never used MK3 W58 front half, I didn't wanna take that chance in case it doesn't work...
Old 04-30-12, 03:35 PM
  #124
AnonymousG
AnonymousG's Avatar
Ok, theres a guy near me selling a SC W58 driveshaft. if it comes down to me buying another driveshaft
Old 04-30-12, 03:42 PM
  #125
99SC42
99SC42's Avatar
^^^Mk4 driveshaft will not work i know this, because i put both driveshafts side by side and the SC300 driveshaft is longer. the SC wheelbase is longer than the MK4 supra that answers alot of questions right there.
Old 04-30-12, 04:54 PM
  #126
VileFCboy
VileFCboy's Avatar
Alright thanks dude
Old 04-30-12, 04:58 PM
  #127
AnonymousG
AnonymousG's Avatar
Ok, thanks. I'll just sell this MK4 DS and pick up that SC one.
Old 06-06-12, 06:23 PM
  #128
azriel
azriel's Avatar
can a stock soarer clutch pedal be used in place of the 400 dollar kit?
Old 06-06-12, 06:33 PM
  #129
99SC42
99SC42's Avatar
Is your car a right or left hand drive?
I don't think you can use a right hand drive pedal in left hand drive car..specially the clutch pedal but don't quote me on that.
Old 06-06-12, 06:35 PM
  #130
azriel
azriel's Avatar
I thought they would use the same part as toyota since the soarer is the same as the sc300/400, and the sc300 came with manual shift from the factory.
my car is left hand drive (when i buy it) sc400.
I suppose the obvious solution is to just buy an sc300 clutch pedal and master.
Old 06-06-12, 08:23 PM
  #131
ishootstuf
ishootstuf's Avatar
I'd say look up the part numbers at toyo diy.com
Old 06-07-12, 04:56 AM
  #132
99SC42
99SC42's Avatar
It's not the same part numbers right hand drive and left hand drive are different.
gl
Old 08-27-12, 03:37 PM
  #133
kingblack
kingblack's Avatar
I'm thinking about doing the auto to manual swap on my 99 Sc 300. This is a great post.
Old 09-03-12, 10:20 AM
  #134
G0TB00ST
G0TB00ST's Avatar
too bad no one made this for the 2nd gen gs. All i need to know is if there is a trans mount made. Ill keep searching. still very informative!
Old 09-20-12, 10:55 AM
  #135
xsc2jz
xsc2jz's Avatar
Interesting thread,
But im wondering if anyone knows exactly what parts do i need to do a swap from a w58 to r154.
My car is already a 5spd, w58 installed, but i want to go with the r 154 since the w58 wont be able to handle the gte swap.
I already have the r154 tranny with the mk3 fron DS.
Can anyone here tell me exactly what parts do i need to get it done.
Thanks
Quick Reply: Looking to do a r154 or w58 manual swap? look in here, dont make a thread.
