Climate control just blows air, not cold, not hot.
Ok I've searched this fourum up and down and cannot find anyone else with the issue I am having, IDK maybe its the key words i'm using, but I did try to search. Ok on to my issue. I have a 94 SC400 the climate control turns on and blows air with no problems, fan seed and mode selector all work fine and the fuses are all good. But the Climate control wont blow cold air, and wont blow hot air. It just blows air. What can possibly be the issue here? Any help you guys can provide would be awsome. Thanks.
I have the exact same issue actually, i don't have heat or a/c.
I can tell you right now that I know for a fact the no a/c is because the system has a leak and has leaked out most of the refrigerant over the years, but unfortuneately it's R12 so to recharge it will be very pricey.
The no heat situation is a little trickier, I changed my thermostat with no change, and have tried reverse flushing the coolant with no luck. So i suspect it is either a blocked heater core, or if you're car has a heater control valve, that could also be the culprit.
Weird but true i have a similar problem no A.C and the heat hardy works......Unsless the fan is set low i checked my coolant its ok but i can't help but notice the upper water hose has a swelling mark at the base and when the car is up to temps its very stiff im deff gonna change the Rad cap asap.
Gonna change the hoses? I knew someone who failed to replace the hoses and it cost him a perfectly good 2jzge motor.
Have someone press the heater button and watch the heater control valve in the engine bay to see if it actuates.
check for ac codes
i think it was key to 'on' then simultaneously press 'recirculate' and 'auto' buttons down to access the ac diagnostics.
check for ac codes
[QUOTE=RyanV;5469199]Gonna change the hoses? I knew someone who failed to replace the hoses and it cost him a perfectly good 2jzge motor.
Im looking to get some Silicone hoses,This morning i let my car get up to temps the i stuck a funnel in the cap hole and i was suprised how much air was in the system.
Floobydust
02-07-07 09:10 PM
