Wtf!!!
OK I finally decided to na-t my sc3 so i wanted to start with the fuel then to the turbo. so i go and pull out the stock fuel pump and then replace it with the walbro GS331 and i washed and reused the stock strainer. so right as i'm putting the stock clamp harness on the fuel pump and right when i'm about to nut due to a completed job!!! the clamp ends up not fitting and to make it worst i cant find anywhere that could just sell me the clamp buy it's self!!! ![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
so my question is....
there anyway i can modify the plug to get the pump to work or know of a place where i can get the harness so i can move on to the 550cc injectors at least those are plug and play!?! ![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
i will take pic's if possible tomorrow
so the walbro fuel pump that you bought didn't come w/ a harness? just did mines recently, you will need the harness for the fuel pump and cut the stock harness then connect/solder them together. after that i use a hose clamp to strap it around the fuel pump holder thing so it'll stay put. i recommend getting a new filter as well.
