Help me identify these sensors? 99 SC300 VVTi
Hey guys, can ya help figure out what these sensors are? Im doin sort of a hybrid setup using a GE ECU and harness too run a GTE (for emission purposes).
Also the pics of the pressure valve below get a vac line from the pressure canister, but I obviously cant run the part of the valve thats inside the intake manifold. Think I could just hang the pressure valve by the pressure canister and put the vac line on it? CEL maybe?
Thanks guys
Thanks guys
Thanks guys
Thanks guys
The 3rd and 4th pics are part of the EGR system. That's the diaphragm that opens and closes the butterfly damper inside the intake. The static state is fully open (ie. if you disconnect the vacuum line, it stays wide open). Are you running a full EGR setup? If not, I don't believe there is any intelligence to that part of it to worry about; just cap or plug the line that ran to the diaphragm.
the second picture is the for the throttle by wire control, the first is the motor to actually run the throttle by wire. u need all that plugged functioning. otherwise u get only like 15 percent throttle
So if Im using the GE harness and ECU too run my Aristo GTE (of course with a MAP2), do I need these plugged in or am I going too get a CEL?
Shinniesft
IS - 1st Gen (2001-2005)
06-09-21 08:30 PM
mmaxie
Performance & Maintenance
05-08-17 09:01 AM
HiPSI
05-22-13 08:52 AM
