Symptoms of failed timing belt?
Old 05-19-10, 11:36 AM
MuGGzyx
MuGGzyx's Avatar
Default Symptoms of failed timing belt?
Still trying to diagnose whats wrong with my car.
What would happen if your timing belt failed/snapped?
Old 05-19-10, 12:36 PM
xx69xx
xx69xx's Avatar
If you timing belt failed then you would have no compression in any cylinder. If you suspect it failed pull off the cam gear cover.
Old 05-19-10, 03:04 PM
Gspec
Gspec's Avatar
Will spin over really fast if the belt broke, or if it jumped enough teeth.
Old 05-19-10, 03:18 PM
Ali SC3
Ali SC3's Avatar
you should post up what is wrong with your car. failed timing belt is an obvious one. a visual inspection is the quickest way to tell if you take the cover off.
Old 05-19-10, 03:29 PM
MuGGzyx
MuGGzyx's Avatar
Ya I am kinda hoping to be able to tell without putting hours of labor into taking covers off etc.
Car died, wont start but does turn over np, gave Code 12 RPM sensor on CEL
Old 05-19-10, 05:35 PM
Ali SC3
Ali SC3's Avatar
there are 2 timing belt covers that wrap around each distributor on the sc400.
I dont think it takes more than a few minutes to remove them.
http://www.lextreme.com/timing.htm step 8 is all you need to do
I like to check my timing belt periodically. its a good thing.
Old 05-20-10, 08:45 PM
vangb2
vangb2's Avatar
compression test would be the easiest way to check for broken or stripped belt if you can crank you engine without any interference.
mooseboy84
10-31-15 11:35 PM
RemSteele
SC- 1st Gen (1992-2000)
17
06-27-11 10:33 PM
MarkMacGS4
Maintenance
08-08-02 11:40 AM
GSquicksilver
Maintenance
05-16-02 07:23 PM
Quick Reply: Symptoms of failed timing belt?
